有意者 请将简历发至 hzeng@nvidia.com
QUICK-TURN PROGRAM MANAGER #1298150/1311173
RESPONSIBILITIES:
- Manages graphics cards and motherboards assembly requests on prototype / quickturn (QT) manufacturing environment at NVIDIA's Contract Manufacturer (CM).
- Involves in manufacturing scheduling.
- Monitors and follows-up deliveries of materials / finished goods.
- Understands, clarifies and implements special requirements from build requestors.
- Be flexible supporting a high-mix, low-volume manufacturing environment.
- Co-works with local CM and other internal departments (both locally and in HQ) to ensure on-time delivery.
- Mobilizes appropriate resources to resolve operational issues hindering on-time delivery.
- Reviews and reports the overall business performance of QT operations regularly.
MINIMUM REQUIRMENETS:
- BS degree holder in Industrial Management or related field.
- Fluent in Putonghua and English, both written and oral.
- 5+ years PM work experience in related industry.
- Must have significant experience in managing PCB assembly programs.
- Sounding knowledge in all stages of getting product to production.
- Experience in new product introduction (NPI) from design phase to production phase is a plus.
SYSTEM DESIGN ENGINEER #1304979
Designs, defines and implements complex system requirements for customers. Supports the entire product lifecycle from New Product Introduction to obsolescence.
RESPONSIBILITIES:
- Prepares studies, analyzes existing systems and uses this data to meet customer specifications
- Qualify memory subsystem on NVIDIA boards
- Determines system specifications and working parameters for hardware/software compatibility
- Collect and analyze signal integrity data using high speed oscilloscopes
- Work with NVIDIA engineering groups to support released boards
- Work with new derivative boards or new boards with alternate components
- Collect and analyze signal integrity of affected circuits using advanced test equipment
- Work with SW team to generate BIOS and ensure BIOS works on new boards
- Develops, recommends and implements corrective actions
MINIMUM REQUIREMENTS:
- BSEE (or equivalent) required.
- Familiar memory qualification process is a plus.
- Must have the ability to work well in a team environment and have good written and verbal communication skills.
SYSTEM DESIGN ENGINEER #1312668
Designs, verifies and implements automotive system requirements for customers. Supports the entire product lifecycle from New Product Introduction to obsolescence.
RESPONSIBILITIES:
- Researches, designs and develops failure analyze tools and methods to insure board production in automotive quality and standard
- Verifies new release test package including all necessary changes and improvements
- Collects and analyzes production board failure data
- Works with NVIDIA engineering groups to support released boards
- Works with SW team to generate test package and ensure test package works on new boards
- Investigates automotive production board level failure analyze activities and unexpected problems
- BSEE (or equivalent) and 3+ years of working experience are required.
- Familiar automotive board qualification process and Linux Ubuntu are a plus.
Sr. Manufacture & Process Engineer #1311073
RESPONSIBILITIES:
- Interface with Contract Manufacturer (CM) on daily operations of QT (quick turn / prototype) PCBA manufacturing line, covering aspects including (but not limited to) process (SMT, & PTH), Test, Material, workmanship, and Quality.
- Perform and review First article inspection
- Perform DFM on new product and gathering/compile input from CM
- Provide onsite support to QT production to secure confirmed delivery, resolve issues hindering on-time delivery, and process troubleshooting.
- Working in a high-mix, low-volume manufacturing environment.
- Communicate & work with internal customer on special requests and expectations.
- Translate internal customer expectation & requirement to CM
- Monitor, prevent and resolve process/manufacture/test/quality issues of CM.
- Responsible for ensuring execution of corrective actions and continue improvements at CM.
- Audit CM's process and quality systems for compliance with NVIDIA requirements for manufacturing of product.
- Monitor CM performance (PM and SPC, etc. and provide reports)
- Strong communication skills (written/verbal) and in depth knowledge of various process
- Bachelor degree, major in electronic, electrical, industrial, mechanical, or manufacturing engineering.
- Fluent in Putonghua and English, written and oral
- Preferable certificated CET6.
- Ability to work at fast phase manufacturing environment.
- 8+ years PCBA manufacturing, Testing, and Quality work experience (SMT, PTH, Reflow, Wave, Testing, and Quality System).
- Flexible working schedule
- Positive attitude, self motivated and team player.
- Hands on Functional test and debug
INDUSTRIAL DESIGNER #1312028
Work on a corporate level across product lines while ensuring consistency for Brand identity. Collaborate with marketing and engineering to assure successful implementation of industrial designs and packaging solutions.
You must Integrate effectively into a multidisciplinary group and propose product designs considering high volume manufacturing techniques and work with Mechanical Engineering to implement. You will produce 2-D concepts, 3-D mockups and have basic model making skills to illustrate design direction and product feature detailing. Illustration techniques and visual presentation skills are a high priority.
Primary areas of design experience:
- Industrial Design and illustration
- Some graphics
- Packaging
You will work in Adobe Illustrator, Photoshop, and Rhino surfacing software or similar. Knowledge of solid modeling software desired, Pro-E preferred.
- Good spoken and written English communication skills.
- Understanding of engineering, production, and manufacturing processes.
- Requires excellent analytical skills, creativity, problem solving and team work skills.
- Ability to present ideas and goals effectively.
- Candidates must possess a BA/BFA degree in Industrial Design and three years of Industrial Design experience.
- Illustrator, Photoshop, Rhino or Alias or other relevant design software.
SR. QUALITY & MANUFACTURING ENGINEER #1316989
RESPONSIBILITIES
- Auditing CM manufacturing process and quality systems for compliance with NVIDIA requirements for automotive products.
- Setup and daily monitoring of PCA assembly and test processes for automotive product lines. Monitoring performance through gathering relevant data and producing statistical reports.
- Providing technical expertise of manufacturing assembly technologies and processes and support to CM engineering teams from NPI through mass production, EOL and RMA process.
- Investigating operational problems affecting production. Troubleshooting and identifying root cause of factory line failures. Interfacing with internal teams to quickly and effectively contain any type of production issues. Maintaining failures and scrap inventory.
- Regular review meeting with CM, and responsible for ensuring execution of corrective actions and ongoing quality improvements at CM.
- Follow up customer quality issues through factory and provide action plan.
- Bachelor degree, major in mechanical / electronic engineering.
- Good English in writing and spoken.
- Former manufacturing process engineering experience in automotive products of the following areas: SMT, assembly and rework.
- Familiarity with PCB types and finishes, IC packages, BGAs mounting and rework methods.
- Familiarity with the characteristic of automotive grade components,
- Certified with IPC-A-610 class III.
- Well trained and Certified with TS16949.
- Familiarity with automotive product testing is a plus too.
SR. QUALITY & MANUFACTURING ENGINEER #1317020
RESPONSIBILITIES:
- Prepare Auto QMP supplier quality management section.
- Perform First Article Inspection review in CEM IQC to assure compliance to specifications.
- Audit supplier process and quality systems with related NV team for compliance with NVIDIA requirements for manufacture of System auto product.
- Setup and daily monitoring of PCA and system assembly and test processes.
- Monitor Auto product sub-tier suppliers performance through gathering relevant data and producing statistical reports.
- Providing technical support to CEM teams from NPI through mass production.
- Investigating potential component quality problems which may affect production and implement continuous improvement.
- Troubleshooting and identifying root cause of factory line failures related to auto suppliers.
- Responsible for ensuring execution of corrective actions and ongoing quality improvements at Auto suppliers and verify its effect.
- Review and support engineering changes to eliminate ambiguity or conflicts with part fabrication.
- Assist with break-in analysis & tracking as needed;
- Work with internal team (planner, PM, buyer, Engineering) and CM factory to achieve production quality and delivery commitments through good quality components supply.
- Bachelor degree, major in testing / mechanical / electronic engineering.
- Fluent English in writing and spoken, preferable certificated CET6.
- Abundant experience on Auto component quality management experience.
- Ability to work under pressure in factory environment.
- Willing work over time or travel on business around Guangdong, Chongqing, Chendu and area Shanghai.
- Hard-working, positive attitude and high spirit of team work.
- Knowledge of SMT/ PCBA is a plus.
COMPONENT SUPPLIER QUALITY ENG #1318172
Responsible for component quality for mechanical parts such as cables, fansinks, plastic and metal parts.
Qualify supplier product and process prior to production release.
Ensure quality control of component manufacturing and assembly processes including First Article Inspection (FAI) of prototypes and source inspection of production parts.
Provide DFM feedback to the mechanical and design engineers in China and the US.
Issue and close supplier corrective action requests and failure analysis reports.
Facilitate supplier development and qualification.
Perform audits and generate supplier quality report cards.
5 years with electro-mechanical component manufacturing experience.
Exceptional communication and interpersonal skills.
Hands-on industrial experience with extrusion, stamping, casting, and other metal working processes and plastics injection molding process.
Hands-on industrial experience in the assembly and quality control process of electro-mechanical assemblies.
INDIRECT PROCUREMENT BUYER #1320738
RESPONSIBILITIES:
- Day to day indirect procurement activities for all NVIDIA offices in China
- Communication with NVIDIA internal customers on purchasing needs and orders
- Requesting for quotes, negotiating best purchasing deals with suppliers
- Sourcing activities
- Must have strong English skills
- Strong purchasing execution and sourcing skills
- SAP and other procurement s/w knowledge a plus
- Work experience in international corporation a plus
Program Manager, Automotive #1320868
Job Description/Qualifications: Plans and directs schedules, monitor project deliverables and provides project status. Organizes interdepartmental activities to ensure project completion on new or existing products. Communicate schedules and deliverable within the organization as well as to customers. Oversees all NPI activities on Operations side and managed handoff of design package from Design Engineering to Operations. Manages NPI interface between Operations and other NV teams (Sales, Engineering, Marketing) Qualifications: 5 years experience as a PM in the Automotive industry BS is required Must have experience in managing Automotive board and systems programs Must be familiar with all stages of getting products to production in Automotive business environment Must have experience managing customer requirements for Automotive business Fluent knowledge of English required.
Process Engineer, Automotive 1320872
Job Description/Qualifications: * Change and Configuration Management for Automotive business * Support for Deviations creation * Support for customer critical sample process and customer Qual sample process * Review of customer documentation and packaging requirements * Design and maintenance of all related product markings (labeling) * Manage design of packaging in full compliance with customer and legal requirements * Provide training on NV product documentation and processes to other personnel (production and engineering) as needed * Perform CM rediness reviews to ensure compliance with QMP/AVL and facility requirements * Supporting and working closely with daily production, engineering, and management personnel
* Strong communication skills with shop floor and management teams
* Performs first article approval and product audits
Qualifications: Minimum BS in engineering or related science from a four year university. Minimum of 2 years experience with high speed SMT manufacturing equipment. Prefer experience in Automotive area. Strong written and oral communication skills. Good problem solving and communication skills are a must. Proficiency in MS Office, MS Project, Share point, Windchill a plus. |
