NVIDIA 社招 Mobile SW Tools Engineer (Debugger)
楚狂人 发表于 2010-11-8 12:51:02 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
有意者请将中英文简历发至hzeng@nvidia.com;(请注明应聘职位)
Job Title: Mobile SW Tools Engineer (Debugger)
Number of Openings: 1
Job Description/Qualifications:
The successful candidate will insure the productization of acomplete GDB / Eclipse Debugging solution for our Tegra developmentkit. He will also extend the solution to support advanced features ofthe Tegra platform, to provide developers with the appropriatedebugging environment that will foster the adoption of the uniquecapabilities of the platform.
  • RESPONSIBILITIES:
    • 5+ years of experience in SW development on Mobile/Linux/Embedded platforms
    • Deep knowledge of the gnu toolchain (makefiles,...)
    • Do you mean GCC, GDB, and binutils.  Make is a secondary tool.  Combine this with Gcc toolchain.
    • GDB and GDB MI interface
    • Development of Eclipse plugin
    • Primarily Java development
    • and GDB extensions
    • Primarily C development
    • Gcc toolchain (Compiler, Linker, Disassembler)
    • Knowledge of DWARF/ELF format is a plus
    • Multicore debugging
    • Experience with Multicore ARM architecture is a big plus
