3.5 minimum observation time T
the minimum time necessary when counting clicks (or where relevant counting switching
operations) to provide sufficiently firm evidence for the statistical interpretation of the number
of clicks (or switching operations) per time unit (see also 7.4.2.1)
3.6 click rate N
in general the number of clicks or switching operations within one minute; this Figure is being
used to determine the click limit (see also 7.4.2.3)
3.7 click limit Lq
the relevant limit L for continuous disturbance, as given in 4.1.1 for the measurement with the
quasi-peak detector, increased by a certain value determined from the click rate N (see
also 4.2.2.2)
The click limit applies to the disturbance assessed according to the upper quartile method.
3.8 upper quartile method
a quarter of the number of the clicks registered during the observation time T is allowed to
exceed the click limit Lq
In the case of switching operations a quarter of the number of the switching operations
registered during the observation time is allowed to produce clicks exceeding the click limit Lq
(see also 7.4.2.6).
上四分位法:简单的理解就是决定click的限值后,在最小观察时间内,假设观察到click的数目为N,则允许有不超过N/4的数目的click超过该限值。在这种情况下认为click的测试项目是合格的。如果超过了N/4,则认为该测试项目失败。
3.9 toy
product designed for, or clearly intended for use in play by children under 14 years old.
Toys may incorporate motors, heating elements, electronic circuits and their combination.
The supply voltage of a toy shall not exceed 24 V a.c. (r.m.s) or ripple-free d.c. and may be
provided by a battery or by means of an adapter or a safety transformer connected to the
mains supply
NOTE Transformers, converters and chargers for toys are considered not to be part of the toy (see IEC 61558-2-7).
3.10
battery toy
toy which contains or uses one or more batteries as the only source of electrical energy
3.11
transformer toy
toy which is connected to the supply mains through a transformer for toys and using the
supply mains as the only source of electrical energy
3.12
dual supply toy
toy which can be operated simultaneously or alternatively as a battery toy and a transformer toy
