EN55022:the common mode impedance towards the right of the 150ohm resistor shall be sufficiently large as not to affect the measurement. Use Clause C.2 to measure this impedance which should be much greater than 150ohm so as not to affect the measurement for frequencies emitted by the EUT.
从这可以看出这个150ohm的电阻就是为电流钳远离EUT的方向提供一个共模阻抗。当屏蔽层150ohm接地时,去耦夹那边的阻抗需要很大,以免对其造成影响。根据C.2中共模阻抗的测量方法,这个阻抗对测量的共模电流影响很大,但是奇怪的是在实际中好像影响不大,有木有emc前辈对这个做过研究,求真相! |
